4.4.15 Won't Run
k2qo
4.4.15 Won't Run
Unread post by k2qo »
Hi Gang,
Another question. I loaded the latest version onto my newish Intel MacBook Pro. When I start the application, I get this error message.
An exception of class NilObjectException was not
handled, The application must shut down.
Any ideas?
Mark K2QO
FN03ra
Re: 4.4.15 Won't Run
That's not a good starting point. :cry: :cry: :cry: Go to your Home folder and look for the file „RumLogOwn.plist“ in the /~/library/preferences folder. Delete this file and try again. I noted few crashes during start up as well. I was not able to find the problem yet, since this happens never in the development environment.
k2qo
Thanks Tom. The plist file deletion/creation fixed the crash.
Now how about my question on the G5? If that would work I can buy new Mac stuff, upgrade the XYL **AND** buy an iPad!
Mark K2QO
FN03ra
Fine, when you have the file still in your trashcan, please e-mail me the file for investigation.
RUMlog should run on a G5, why do you don't try it out?
K9TF
Unread post by K9TF »
Then maybe it was not RFI that caused my issue.
I had to delete all my version of RUMlog off the computer. I haunted down all of my K9TF.rsd files as well and deleted those or renamed them. I then downloaded 4.5 again and installed it.
Seems that the program hunted various parts of the older programs on the computer.
Sure glad I have Time Capsule to restore what I needed to, to get going again. Hope this helps.
Keep the faith, Jim K9TF
Jim K9TF
