How does the cheat database work?
sa6zgm
Unread post by sa6zgm »
In Skookumlogger and N1MM there's a feature that suggest probable signals once you start to write a callsign. Is that what the cheat database does in RUMlogNG? If so, I can't get it to work. I suppose I would really like that feature to work in RUNlogNG :)
Arne SA6ZGM
Re: How does the cheat database work?
The Cheat database shows club member numbers, names, grid squares, States, Provences, etc (if applicable for this specific contest) after you have finished the call sign entry.
I guess you are talking about the Super Check Partial: https://dl2rum.de/RUMlogNG/docs/en/pages/InContest.html
Before you can use it, you have to download data: https://dl2rum.de/RUMlogNG/docs/en/page ... ntest.html
sa6zgm
Oh dear, that was easy -
I've learnt something today :) Thank you!
ea5xq
Unread post by ea5xq »
How could be updated? For instance for CW Ops Mini test is out-of-date, thanks
73's Juan, EA5XQ
http://www.ea5xq.net
I've just updated the database. You can download it using the Online menu.
ea5xq
Thanks!
73's Juan, EA5XQ
