Printing to QL 700
Jacques
Printing to QL 700
Unread post by Jacques »
Hello Is anyone successfully printing to a QL-700 ? I have followed all instructions on the website etc. but to no avail .
If one has done it succesfully I would be grateful for your settings
Using labels brother DK. 11201 ( 29mm X 90mm)
Thank You
Best 73s Jacques F1VEV
Jacques
Re: Printing to QL 700
Hi gave up on the QL 700 unfortunately worked well with other bloggers I had in the past.
went to printer paper Avery etc and its fine however how not to Print Via ..... Etc or all other detail with seems to be in the comment box ?
I just want the stations call sign
Thank you
wd8cyu
Unread post by wd8cyu »
Hello Jacques,
I am testing a Brother QL-500 from a fellow ham with RUMlogNG 6.4.3 and I got it to work but it was quite painful.
I had to jump through a lot of hoops to get the Brother driver to work on MacOS 26.5.1. I installed a very,very old CUPS driver from MacOS 10.15 first.
In "Settings > QSL" selected Dymo (90mmx29mm) as this is the closest match to a standard mailing label (in USA) which is 1.14 x 3.5 inches. (this is the only label I had available for testing)
In RUMLogNG Menu > Edit > Page Setup I used "Standard Address Label". I was able to finally get the QL-500 to print QSL labels. I only printed a few of them because it does not belong to me but it did prove RL did work printing to the QL-500.
I will probably NOT use this solution going forward because it is very dependent on deprecated software (drivers). I will try to find a used Dymo 450 Labelwriter and hopefully avoid all these issues.
See attached screenshots.
73, Kevin - WD8CYU
Jacques
HI Thanks
did get it to print but too fidly. since I do not do a lot of QSL card , only respond when received I will stick to the P touch templates I made .
Thanks again and take care
73 Jacques
