IC7300: S&P is not activated by moving VFO
ew1sk
Unread post by ew1sk »
Description
By design: "S&P (Search and Pounce) will be activated as soon as you move the VFO", but with ic7300 it doesn't work.
STR
1. Open Contest window
2. Activate Running mode
3. Rotate VFO
Actual result
Running mode persists
Expected
S&P is activated
73, Serge <ew1sk>
Re: IC7300: S&P is not activated by moving VFO
Well, currently it works only when there is a callsign entered and the option Menu-->Logbook-->Clear after QSY is activated.
ew1sk
Ok, it would be nice if it gets fixed.
73, Serge <ew1sk>
