TQSL Uploads not working
VE3MM
Unread post by VE3MM »
GM
Using Rumlog 5.19.3 and OSX 13.7.5
I am unable to upload to LOTW and get the following error message:
"Error tqsl.app bookmark data". "This file couldn't be opened because it isn't in the correct format"
I have the TQSL 2.8 installed and the files are in the USER directory.
I have rebooted the computer to try and correct permissions.
Any ideas for a fix, please?
Rick ve3mm
Re: TQSL Uploads not working
Try the solution from here: viewtopic.php?t=1888
VE3MM
That procedure worked. Thanks Tom
Rick ve3mm
