USB-C Serial Adaptor
Posted: Tue 22. Apr 2025, 16:23
I just upgraded the station computer to a new M4 iMac. The previous was an M1 MacBook Air.
I had been using using the FTDI serial cable available from Elecraft to connect to my KX3. It works fine, but is USB-A instead of USB-C as used on the more recent Apple, and I guess other, computers. So, I thought to change the serial adaptor to simplify things and make it all prettier instead of using the Elecraft FTDI serial cable adaptor and a short USB-C to USB-A cable.
So, I bought one of these:
Adafruit FTDI Serial TTL USB Type C cable
It doesn't work with either RUMlogNG or WSJT-X.
Yeah, the device shows up in the Settings panel on both. It shows up in the macOS System report. If I connect an oscilloscope to the transmit line and send messages through CoolTerm, I can see the levels toggling as they should. If I connect RXD to TXD anything I type into CoolTerm gets echoed back to the CoolTerm panel.
Anybody have any idea of what I might be doing wrong with this cable? Or, does anybody have a suggestion for a good alternative?
