DX Spots ALL not sorted by last received
Posted: Tue 25. Mar 2025, 08:17
by ea5xq
Although DX Spots Windows shows individually (per band) sorted by last DX received, ALL tab do not. I remember that previously it did it. Which is the criteria to be shown in ALL tab?
Re: DX Spots ALL not sorted by last received
Posted: Wed 26. Mar 2025, 10:06
by ea5xq
Just an example
3B9DJ arrived 3' ago, FK8IK in 17m 30' ago and when watch ALL see what happens
it is like some old spots remain at top as they would be spotted right now but it was half an hour before
Posted: Fri 4. Apr 2025, 13:00
You have sorted the All table by dx de.
Posted: Fri 4. Apr 2025, 16:19
by ea5xq
May be that picture was sent by mistake, look at these ones, are not sorted by DX and the first spots are older if you go to the specific band,
I do not know whether the problem comes from the DX CLuster, I do not know how ALL collect the spots
Posted: Sat 5. Apr 2025, 14:18
by ea5xq
Closed, I found the problem (I think)
Posted: Sat 5. Apr 2025, 14:25
It would be helpful for others, when you share your experience.
Posted: Sat 5. Apr 2025, 16:22
by ea5xq
Yes, you're right, apologies although I am not sure whether it is fine
In DxSpots I was not able to show the column FOR in order to order the spots by time , although I selected it it did not appear. I had to delete most of the columns and add FOR one and include new ones so now I am able to control the arrival of the spots
I will check it out later on to be sure that it solved the problem
