SatPathFinder TRX Control Doppler shift compensation
db4ta
Unread post by db4ta »
today I wanted to work with RS-44 (SSB transponder) with the Icom 705 and the automatic trx control with retuning of the Doppler shift.
The compensation of the Doppler shift works well in FM, in SSB I noticed that it is not possible to change frequency for search a QSO partner on a 60kHz wide transponder in portable mode because the frequency is always reset. Would it be possible to change the TRX control in a future version so that manual tuning is possible via the VFO of the 705 and the Doppler compensation takes over again after the change with the new frequency?
Best 73 from DB4TA
Alex
Re: SatPathFinder TRX Control Doppler shift compensation
  • Connect to the TRX, switch on TRX Control to set bands and modes initially.
  • Switch off TRX control.
  • Use the VFO knob for tuning.
  • Once you have found a station press the button with the down pointing arrow.
db4ta
Good morning Tom,
thank ms for the quick response!
I am sorry, I had to RTFM before. :roll:
Found it and will try next weekend.
73 de DB4TA
Alex
