Omit printing QSL cards with “W” set in QSL field
VE3AJ
Unread post by VE3AJ »
Since LOTW has become so popular it has changed the way I do outgoing QSL cards.
I only send paper cards to Hams that have sent me a card. Paper QSL card in QSL field set to “R”
For new QSOs
Can the default setting in the QSL field be selectable to “-“ (ignore) instead of “W” (worked).
Would allow an easy solution to avoid printing unwanted labels/cards
Jim
VE3AJ
VE7KAJ
Re: Omit printing QSL cards with “W” set in QSL field
Set it to - and save a QSO. Then it will become the new default.
VE3AJ
Thanks works well for QSO entered directly in RumlogNG
How can this be setup for QSOs entered by WSJT?
JIm
See the WSJT-X settings under the UDP tab in the Preferences.
VE3AJ
Found it thanks
And thanks for your patience
Jim
