Wi QSO Party
N2TSQ
Wi QSO Party
Unread post by N2TSQ »
I worked the Wisconsin QSO Party last weekend and noticed that the multipliers for the US states and Canadian Provinces are not being included. All the Wisconsin County multipliers are working correctly. In the program language, it looks like Multipliers #2 is not being included and only shows a value of 1. Is there something I am not doing correctly?
Thank you in advance!
Bob, N2TSQ.
(PS, Longtime RUMLOGNG User with over 22800 QSOs! Works great!!)
Re: Wi QSO Party
No, it's not your fault. There is a bug in the WIQP contest template for WI stations. Your log should be correct for submission, since scoring is not part of the Cabrillo.
Please try the corrected version to get correct scoring: https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip
  1. You have to export your QSOs via ADIF using the Contest Menu.
  2. Create a new contest file, using the WIQP template.
  3. ADIF import the exported QSOs using the Contest Menu.
  4. You should be fine.
When you have logged few QSOs only, just run the new version and double click each QSO entry and press Enter. This will correct the scoring as well.
N2TSQ
Re: Wi QSO Party
Ausgezeichnet! Alles geht gut. Vielen dank. 73 Bob, N2TSQ
