LOTW - Change Mode FSK to DATA
Posted: Mon 8. Jan 2024, 22:01
by VE3MM
I did a search for the answer to this in the manual and in the forum so I hope this has not been covered before.
LOTW rejects my RTTY qso uploads which are shown in RumlogNG as FSK as being a incompatible mode. LOTW is expecting RTTY qso's to be shown as DATA mode.
It does not appear possible to make this change when using RumlogNG qso editors as DATA is not shown in the mode drop down menu.
Can someone please point me in the right direction on this?
Rick ve3mm
Re: LOTW - Change Mode FSK to DATA
Posted: Tue 9. Jan 2024, 00:03
FSK is not a valid mode. How did you logged it? Even Data is not a valid mode.
In TQSLs preferences you could map FSK to RTTY. Or edit the QSOs and set the mode to RTTY. See Preferences -->Modes/Sat to choose the modes you want to use.
Posted: Tue 9. Jan 2024, 00:54
by VE3MM
Hi Tom
I appreciate the quick reply.
To answer your question, I used Skookum Logger for the contest and it generated the FSK mode setting, which got imported to RumlogNG as an .adi file.
I didn't know about the mapping availability in TQSL.
I did get around this by editing by hand all 235 entries in the log in Skookum and changed them to Data. I deleted the qso's in RumlogNG and then imported the edited file. RumlogNG then uploaded the qso's correctly to LOTW.
Initially I tried global edit of the .adi file with a text editor but it got messed up. The global edit ended up substituting Dat for Data in all but the first entry. Can't figure that one out.
Anyway, I'll know better next time.
Thanks for your help. Love your program!
73 and HNY
Rick ve3mm
Posted: Tue 9. Jan 2024, 09:37
Even a simple text editor may be a powerful tool. Just use the Find and replace all function to change <mode:2>CW to <mode:4>RTTY within seconds. Familiarize yourself with the ADIF specification and valid modes. I'm not sure why you have ignored the advice to set the mode to RTTY
