WSJTX lockup after Sonoma 14.2.1 Update
Posted: Fri 22. Dec 2023, 14:37
Hello - I have been using RumlogNG for over a year now on my M1 iMac. I have run into a problem which seems to have started occurring after the last Sonoma update to 14.2.1.
When I start WSJTX v2.6.1 it appears to operate normally - however, after 2 -3 transmissions WSJTX locks. The Waterfall freezes and no audio is sent on future transmissions. Force Quit is required to shutdown WSJTX. I reinstalled WSJTX and the same problem occurred. I then tried to run WSJTX alone with rig direct rig control and it works properly.
It appears that the issue occurs when using the DX Lab Suite Commander. I installed JTDX and it is working properly (no issues) - there seems to be some issue with WSJTX DX lab suite connection after the latest Sonoma update.
Any Help would be appreciated!
