UDP Rotor Control from within RL
Posted: Fri 17. Nov 2023, 17:16
I'm using RL 5.14.4, and am trying to interface it to a homebrew ESP8266 based rotor controller. I've looked at the Rotor app but it seems to want a USB connected rotor controller.
I enabled AppInfo broadcasting on UDP/12060 and I can see packets with the heading I need. Is there a way to initiate a rotor change from within RL though? I see from the Rotor application's documentation that I should be able to click on the Compass icon in the Main Logger window to have RL tell Rotor to move the antenna, but when I do that I don't see anything happening on the network that would indicate that.
IOW, I can see the packets for the heading I want, but no way to tell that the RL user has asked for the antenna to be moved kind of like Alt-J does in N1MM.
Thanks and 73 de Sean N3RTW
