MacOS 14.0 Sonoma tabbing issue
Posted: Sat 30. Sep 2023, 00:42
by K7CAN
Is anyone else experiencing an issue using the 'Tab' key to advance past the call sign? I cant 'Tab" to the signal reports.
K7CAN
Mike
Re: MacOS 14.0 Sonoma tabbing issue
Posted: Sun 1. Oct 2023, 08:19
by ik2eae
Yes, "TAB" works only from frequency fields
Posted: Sun 1. Oct 2023, 10:07
Crazy. After program start the tabbing works, shortly later it doesn't. When I compile the code under Sonoma it works as expected.
Posted: Sun 1. Oct 2023, 19:01
Seems to be a little bit more complicated. It works as expected in the IDE but fails when running the compiled app.
Posted: Sat 7. Oct 2023, 18:26
by Jacques
HI Tab works as planned here through all field Cheers. Jacques F1VEV
Posted: Thu 19. Oct 2023, 16:25
by K7CAN
Thanks for the fix DL2RUM!! I noticed it yesterday
