two sperate callasigns in one logbook ?
Posted: Tue 19. Sep 2023, 07:23
by Jacques
M2Hello new to rumlog and mac .
I have my holiday call sign set up on one log (9M2CJ) and I wish to add my home call F1VEV can this be set up under one software and switch from one to the other or must two seperate software be set up on same compter if so how to do i.e directory etc
Thank you Jacques
Re: two sperate callasigns in one logbook ?
Posted: Tue 19. Sep 2023, 08:49
When you work from different DXCC entities you should use separate logbook files for each used callsign.
Note the option <station_callsign> for a user field if you want to use one log file only.
Posted: Tue 19. Sep 2023, 14:39
by Jacques
""When you work from different DXCC entities you should use separate logbook files for each used callsign."""
Thank you YES agreed but how to do this do I need to download rumlog again and put into another directory ? (I know how t do this on Windows but not Mac
Danke Jacques
Posted: Tue 19. Sep 2023, 14:54
Menu-->Logbook-->New
Posted: Tue 19. Sep 2023, 15:01
by Jacques
Thank you very Much 73s Jacques
