Main logging window date + time shortcut
Posted: Sun 12. Feb 2023, 16:41
by JonathanP
In the main logging window, would it be possible to have either a keyboard shortcut or button to load the current date+time into those fields?
Reason I ask is that often I am waiting to call someone and like to start filling in callsign, report etc before I actually start the QSO. For this reason I find it best to operate in "Enter time manually" mode. But as soon as the QSO actually starts I'd like to insert the current date+time, a keyboard shortcut would be great to do this - would save me having to enter the info manually.
Many thanks & 73,
Jonathan G4IVV
Re: Main logging window date + time shortcut
Posted: Tue 21. Feb 2023, 00:09
by JonathanP
Just a quick update - I found I could use the MacOS Automator to create a "Services->Set QSO time" automation that runs an AppleScript to set the QSO time. I then mapped that service to a key (Cmd+T in my case) in settings, which works nicely to update the QSO date and time fields with the current date+time.
Problem solved!
73 Jonathan
Posted: Sun 26. Feb 2023, 14:09
by HK3W
I think we need this fuction!!
Posted: Sat 25. Mar 2023, 15:46
by JonathanP
@DL2RUM many thanks Tom for the latest update adding the menu item to load the current date and time when set to manual, I'll certainly be making great use of that.
Thanks and 73, Jonathan
