Create a contest file for import
Posted: Sun 15. Jan 2023, 03:30
by wy7wl
Is it possible to create a custom contest file for import? I have a DX trip coming and need to add a few more logging options in the contest window...
Will
Re: Create a contest file for import
Posted: Sun 15. Jan 2023, 05:43
What’s wrong with the dx-ped template? What are your intentions?
Posted: Sun 15. Jan 2023, 15:51
by wy7wl
If the note, or sent/received saved between QSO I could work around. But I need operator, Sig_info and My_Sig_info if I’m being really picky. With My_Sig_Info saving. I’m headed to Ireland and will be operating with a prefix and also doing POTA at the same time. So without creating a new logbook I was hoping to use a contest window….
I’ll have 3 different Prefixes on this trip at multiple parks. So it will be an organizational nightmare.
Posted: Sun 15. Jan 2023, 16:56
I would do all the logging using the dx-ped template. After that I would import the file(s) into a new ''normal' logbook file. Here we have all the possibilities for batch editing and/or to export for POTA with all required fields.
You could use user definable fields for My_Sig_Info and My_Sig and do the batch editing. Or just use the Export for special activity function from the Logbook menu.
Posted: Sun 15. Jan 2023, 16:58
by wy7wl
Ok I’ll experiment with that.
Posted: Sun 15. Jan 2023, 17:22
by wy7wl
Ok. Wow. I didn’t know about this Export for Special activity… Do you see a problem with naming the Dx-Ped contest file with my prefix and then use operator for park number? I could export selected parks from the contest and then Export Special in main logbook. I’d like to keep one contest for each prefix.
Posted: Tue 17. Jan 2023, 14:39
by wy7wl
After some time playing. I'm just going to create a new logbook... Thanks for the suggestions!
