Change default value for "QSL"?
DK1MAX
Unread post by DK1MAX »
Hi ALL,
I'm new to Mac and RUMlog. Thanks for this great software! Here is my Q:
When logging QSOs the default value in QSL is always set to "W". Is it possible to change the default to "-" or whatever?
Thanks for help
73, Max. DK1MAX.
Re: Change default value for "QSL"?
Hi Max,
the default value after program start is 'W'. But I'm wondering that the value changes after each logged QSO back to 'W'. I'm sure, this worked in another way in the past.
I changed the behavior slightly. The default is still 'W', but the value will not change any longer back to 'W' after logging. Now you can enter once a '-' into the QSL field, and for the following QSOs to enter the new default will be the '-'
I guess, this is a good compromise.
Download the application 4.2.2 only: http://www.dl2rum.de/rumsoft/RUMlogApp.zip
Download the full package 4.2.2: http://www.dl2rum.de/rumsoft/RUMlog.zip
DK1MAX
thanks for quick reply and bugfixing. It works as expected.
73, Max. DK1MAX.
