CQWW contest
Posted: Fri 23. Oct 2009, 17:22
by g0vgs
Just trying to make a plugin for CQWW SSB this weekend which I have pretty much done. I have not found a way to score ones own DXCC properly though. It is not worth any points but is worth a multiplier. Is there a way to do this?
73 Ian
Re: CQWW contest
Posted: Fri 23. Oct 2009, 17:40
by g0vgs
OK, I have it working apart from one thing. I have set an exception for G to score zero points but act as a mult of 1 as per the rules. strangely though, GW, GD etc now score properly but do *not* get the zone multiplier. I am stuck on this one at the moment.
73 Ian
Re: CQWW contest
Posted: Fri 23. Oct 2009, 17:47
For the CQWW is no plug in required. This contest is hard coded in RUMped. Just select this contest, when creating a new log file.
Re: CQWW contest
Posted: Fri 23. Oct 2009, 17:50
by g0vgs
Aaaah, this is WWDX? Sorry I was not expecting that
BTW, in the drop down setup box for the log, you have Passwort which should be password in English.
73 Ian
Re: CQWW contest
Posted: Fri 23. Oct 2009, 20:28
I've not checked the latest rules, I hope the scoring in RUMped is still correct.
'Password' will be corrected in the next version, Tnx
Re: CQWW contest
Posted: Fri 23. Oct 2009, 21:13
by M0JEK
Lernen Sie, Deutsches zu sprechen. Dann ist es nicht ein Problem
Re: CQWW contest
Posted: Fri 23. Oct 2009, 22:33
by g0vgs
M0JEK wrote:Lernen Sie, Deutsches zu sprechen. Dann ist es nicht ein Problem
Now now Monkey
BTW, what kind of cat is that?
73 Ian
