Sat QSO loggen für qo100dx.club
Posted: Sun 14. Aug 2022, 11:57
Hallo,
Ich habe gerade gelesen welche Daten ich brauche für einen Upload des Logfiles auf der Seite https://qo100dx.club/profile/upload-log
Gibt es irgendwo die Möglichkeit den Sat_Name einzutragen?
Die anderen Felder habe ich gefunden
73 de DD6FM - Marco
73 de DD6FM - Marco
Please upload an ADIF file with your QSOs for the QO-100 satellite.
Your .adi file should contain at least the fields QSO_DATE, TIME_ON, CALL, MODE, BAND that should be "13CM", SAT_NAME that should be "QO-100", and PROP_MODE that should be "SAT".
If present, the field VUCC_GRIDS is parsed according to the ADIF standard (either 2 or 4 grids, separated with ",") and the 4 digit grids listed will be imported in addition to the GRIDSQUARE field.
You can also include your operation grids via the fields MY_GRIDSQUARE and MY_VUCC_GRIDS according to the ADIF standard. If you're operating portable we ask that you upload your logs with this information AND the correct suffix in the callsign.
