Feature Request
Posted: Fri 22. Apr 2022, 19:04
Would it be possible to add a check box option to the TX1/TX2 Preferences so that it would be possible to reset the CAT interface automatically when switching to a selected Transceiver setup? I'm finding some occasional glitches when switching between a WSJT Transceiver setup with no CAT control (controlled by WSJT) and a CW/SSB Transceiver setup where CAT is used. Doing a manual reset from the menu works, but automatic would be nicer.
Not everybody would want the reset (maybe?), which is why I suggest the checkbox. But, if it always would be a good idea for everyone, no checkbox would be needed - just a reset.
This is separate from the 5-10 second beach ball effect I've seen on and off when right clicking on a spot to QSY in the CW/SSB setup. I'm almost sure it's not the driver or any of that, since controls in the CAT control window work immediately. It's when I ask RUMlogNG to QSY from a spot.
In any case, I'm using the standard drivers supplied by Apple for interfacing with the FTDI-serial adaptor that Elecraft supplies. At least I think I am. I certainly haven't installed any other drivers.
