Page 1 of 2
Editing a QSO doesn't stick until the 2nd time
Posted: Sun 20. Mar 2022, 15:16
by k3gx
I have RUMlogNG v5.7 running on MacOS 11.6.4 and have an annoying problem where when I edit a QSO, the popup window comes up, I make the changes, and then hit save - but the changes do not get saved until I open the contact up a second time, make the changes, and hit save again. Am I doing something wrong when editing?
Dave K3GX
Re: Editing a QSO doesn't stick until the 2nd time
Posted: Sun 20. Mar 2022, 15:21
Do you edit one or multiple QSOs?
Which field was changed?
Posted: Sun 20. Mar 2022, 16:27
by k3gx
This happens when I edit one contact at a time. Yesterday, I was editing multiple fields in each QSO including location (city), grid square, and comments. When working SOTA, I like to edit the city to refer to the peak name, the grid square to the grid location of the peak, and put the point value in the comments field. I found that even just editing one of the user-defined fields, such as the SOTA reference, resulted in the same behavior.
Dave K3GX
Posted: Sun 20. Mar 2022, 16:44
One more:
Do you use the iCloud synced logbook?
Most probably the changed data are saved correct, but are shown wrong in the log table.
Posted: Sun 20. Mar 2022, 17:48
by k3gx
Good point. Yes, I do store on iCloud. Does it take time for the entry to update when doing that?
Posted: Sun 20. Mar 2022, 17:53
No, it takes affect right away. All data are stored locally first.
When you observe it again, quit RULog and restart it. Check again. This helps me trouble shooting since I can't duplicate the failure.
Posted: Sat 29. Oct 2022, 18:29
by N7YHF
I have the same issue--editing a single QSO requires two attempts about 80% of the time. I am most often changing the grid locator when WSJT-X doesn't populate it correctly. My logbook is an iCloud-synced one.
I am using RumLogNG 5.10 (544) on macOS 12.6.
Posted: Sun 13. Nov 2022, 17:12
Tab out of the field before you save the changes. When the changes are not seen, restart RL. Are the changes now visible?
Posted: Tue 24. Oct 2023, 22:31
by shadow
I really enjoy using RumLogNG, it's a fantastic piece of software.
I have a similar issue however, sometimes it takes more than twice to edit the QSO. I've also noticed that if I'm scrolling the list of QSOs that it jumps / resets periodically. I stopped using iCloud syncing and both behaviors stopped.
I'm wondering if the iCloud syncing is happening in the background when the QSO is open, maybe a database locking issue?
--Marc
Posted: Thu 26. Oct 2023, 13:00
by KC3TCT
Hello.
I had originally set up to use the iCloud synced log but, somewhere along the way, switched to a local file. This past week, I had switched back to the synced log and had the same issue. I noticed that imports from WSJTX and FLdigi seemed to appear quicker but I would have to edit the info twice before the changes showed. I exported the log to a local file (in the iCloud directory) and the issue went away.
Cheers and 73,
Jim KC3TCT
