Another thought
Posted: Thu 8. Oct 2009, 16:53
by g0vgs
Announcements pop up. Do talks? I don't generally watch the raw cluster feed, I keep the spot window open. If anyone sent me a talk it would be nice if a window would pop up with it in (like announces) It would also be nice if I could repy in the same window. Is this possible?
73 Ian
Re: Another thought
Posted: Fri 9. Oct 2009, 20:15
by DG5MMQ
it sounds like a wishing-list
it would be nice if i could save the open windows on the next restart. maybe in the preferences? If there would be a check-box for the windows that i want to be open on every start - this would bei great for me.
tnxs and 73
Re: Another thought
Posted: Mon 12. Oct 2009, 16:05
Here we are ....
http://dl2rum.de/rumsoft/RUMlogToTest.zip
- Google Earth Auto Look Up fixed
- Separate Talk Window - You can suppress the new opening Talk window in the preferences under the DX-Cluster tab
- Windows reopen during program start - The most useful windows will reopen automatically, no options available
- Terminal
- TNC
- Sun Data
- Drawer
- Grayline
- Grayline Slots
- Grayline Map
- Band Map
Is a window missing?
Please test the Talk window, I'm not sure if every cluster software uses the same syntax.
Send commands in the Talk window --> to go
Re: Another thought
Posted: Mon 12. Oct 2009, 17:02
by g0vgs
Tom you are amazing! Great stuff thanks. A suggestion on the talk window. Could it have a text entry field at the bottom so we could respond to that talk? It would be nice IMHO if the talk was setup for *that* conversation. I don't mind if there are several open (although this pretty much never happens). So the pop up window would belong to the peson who sent the talk, allowing me to reply in the same window. I hope that makes sense. The talk arrives no problem with my clusters which are both DXSpider.
73 Ian
Re: Another thought
Posted: Mon 12. Oct 2009, 17:50
Re: Another thought
Posted: Mon 12. Oct 2009, 22:28
by DG5MMQ
g0vgs wrote:Tom you are amazing! Great stuff thanks.
no more comments on this!
Thank you, Tom
Re: Another thought
Posted: Wed 21. Oct 2009, 08:25
by g0vgs
DL2RUM wrote:Send commands in the Talk window --> to go
OK, it's official, I am stupid
I cannot work this out sorry. Do I use the cluster client window to respond? I cannot get anything to work in the talk window. Can you explain please?
I used the net control while running the UK Elecraft net on Sunday for the first time in anger. What a great feature! I have shown a few others too and they think it is wonderful. I intend to play with the contest version next
73 Ian
Re: Another thought
Posted: Wed 21. Oct 2009, 14:36
It's straight forward.
You get a message and the window opens. ('Talks' must be selected in the Preferences-->DX-Cluster)
- Talk.tiff (24.82 KiB) Viewed 13740 times
To response, just type ahead in the input field and finish with the Enter key.
Re: Another thought
Posted: Wed 21. Oct 2009, 14:47
by g0vgs
OK, I am not seeing what you are seeing, just a plain window like the announcements one with no entry box at the bottom. I will download 4.2 and see if that fixes it. I am still running the beta you posted. (not a language thing is it?)
73 Ian
Re: Another thought
Posted: Wed 21. Oct 2009, 14:53
by g0vgs
OK, I had a plain talk window with the beta but with 4.2 it is obvious
I am not going completely mad then
73 Ian
