Data from N1MM into rumogNG
Posted: Sat 11. Dec 2021, 19:52
by PC9T
Is it possible to get data from N1MM from a different windows computer to log directly into RUMLOGNG.
1 have a windows NUCserver where I can use N1MM for contests, but I don't want to import data by a USB stick into RumlogNG.
So is it possible to get every qso that I make in N1MM that this directly logged into RumlogNG.
And how to setup this.
Not that the combo RumogNG and Fldigi is that bad, but not all contests are available in RumlogNg, but for contest N1mm is easier to setup and to use.
But if not then I must use the Fldigi combo.
Re: Data from N1MM into rumogNG
Posted: Sun 12. Dec 2021, 08:18
There is a N1MM import option in the UDP section of the preferences.
