QSOs from WSJT-X not completely transferred to RUMLog
Posted: Sat 14. Aug 2021, 01:45
by N2TSQ
Just started a new issue when I accept the notification of a new WSJT-X FT8 QSO, it it does not appear in RUMLog and RUMLog becomes unresponsive. If I force quit RUMLog and then restart, the QSO is there (only one at a time).
RUMLog 5.6.3
WSJT-X v2.4.0 c19d62
Log is include sync version. (Not open on any other device)
Any thoughts would be greatly appreciated!!
Bob, N2TSQ
Re: QSOs from WSJT-X not completely transferred to RUMLog
Posted: Sat 14. Aug 2021, 04:48
You should get a Spin report.
Posted: Sat 14. Aug 2021, 11:56
by N2TSQ
Thanks for your reply. I'm sorry, but I don't know how to create a spin report.
Best, Bob. (13748 logged QSOs)
Posted: Sat 14. Aug 2021, 12:20
by N2TSQ
I did some digging and found the "spin report" area in the console application on my Mac however it was empty. I recreated the issue and a report was not generated.
Posted: Sat 14. Aug 2021, 15:20
Seems to be a major problem. I have a fix, hopefully without side effects:
Please try it out and report back.
Posted: Sat 14. Aug 2021, 18:05
by N2TSQ
Just had a quick FT8 QSO and the fix seems to have worked. I'll report back when I have time to test it further. Thank you very much!!
Bob
Posted: Sun 15. Aug 2021, 01:49
by N2TSQ
Good morning!
I collected several dozen new QSOs from FT8 and they all loaded into RUMLog nicely. Interestingly, during the addition of data from HamQTH I would select the QSOs I wanted to overwrite the data and the process only completed about half of the time.
Bob
Posted: Sat 28. Aug 2021, 13:36
by N2TSQ
2 short follow ups....
I am using the RUMLogNG_Test version you sent. Will this get updated to the next version when you release it, what is my path forward?
Secondly, the "Add QSO Data" from HamQTH requires me to follow the process twice. It does not load the information on the first try from the query screen back into log. Might" this be related to the WSJT-X issue you fixed?
Thank you, 73, Bob N2TSQ
Posted: Sun 29. Aug 2021, 03:53
Just make sure you are using always the latest version. The most recent version in the store is 5.6.4 Build 500.
