RUMlog Version 4.1
RUMlog Version 4.1
When you change a main prefix in the dxcc table using the EditDXCC.app it is not longer required to rework your logs, this will be done automatically now. Make sure you have opened all your logs once with version 4.1 to automatically make some changes in the database. After that you can just change the main prefix in EditDXCC.app without any further action. Just reload the log into RUMlog.
The LoTW QSL in Window shows now, if a QSL represents a new one. (not confirmed yet - Paper QSL or LoTW)
New_Ones.tiff
New_Ones.tiff (40.5 KiB) Viewed 8409 times
New_Ones.tiff
The Kenwood TS-570 driver was fine tuned, it works now better for the Elecraft K3.
Very important note
The database structure was changed. When you open a log at the first time in version 4.1, this will be done automatically. Before you start RUMlog 4.1, back up your existing logfiles first! Once a log database file is modified, you can not read it with RUMlog prior 4.1.
Only RUMlog.app was changed.
g0vgs
Re: RUMlog Version 4.1
Unread post by g0vgs »
Ummm, is there an English version? :) The menus are in German, at least on the app only one.
73 Ian
Ian J Maude | G0VGS
K3s #10268
Oops! Try again the download. :oops: :oops: :oops: :oops:
g0vgs
Brilliant Tom thanks :)
73 Ian
Ian J Maude | G0VGS
K3s #10268
DG5MMQ
Unread post by DG5MMQ »
Excellent, Tom!
Thank You
Only one thing, when i start the DX-Cluster Window, it doesn´t scoll down. I have to do it manually. No big prob, but so you know ist. I´m using 10.4.9 maybe because of this?
Well, this is a known bug and it is not under my control. The window is not scrolling correct, when a long text comes in. (connect text)
