DX Cluster terminal settings gone
wb2pkr
Unread post by wb2pkr »
Upgraded to latest version/build (5.4.1/473) this morning. So far everything OK except, my saved DX Cluster Terminal nodes were erased. One incomplete setting called "Kiel" was inserted but as it was incomplete, a connection could not be made. Not a big deal, except I forget which nodes I use.
Re: DX Cluster terminal settings gone
It's always a good practice to read the release notes after installing a new version. See the Help menu or here: https://dl2rum.de/RUMlogNG/docs/en/pages/History.html
The loss of some settings was a side effect of required code changes.
wb2pkr
Would have been more effective if I would have read it BEFORE the upgrade. That way I could have taken note of the clusters I was using. 8-)
5.1 25-November-2020
Caution: DX-cluster access data mut be entered again!
