RUMlog Version 4.0.4
Posted: Mon 3. Aug 2009, 15:18
RUMlog version 4 has a lot of new features and functions. The most important are:
• Enable Satellite QSO logging
• Iota logging and tracking
• Locator tracking
• Dual transceiver support
• Own IOTA and qsl manager database
The User's manual is completely rewritten, see the accordingly chapters in the manual for further information. http://www.dl2rum.de/rumsoft/RUMlogDoc.html
Even if you are familiar with RUMlog, it is recommended to read the whole manual to find a lot of tips, tricks and 'hidden' features.
Very important note
The database structure was changed. When you open a log at the first time in version 4, this will be done automatically. Before you start RUMlog 4.0, back up your existing logfiles first! Once a log database file is modified, you can not read it with RUMlog prior 4.
Download: http://www.dl2rum.de/rumsoft/RUMlog.zip
If you want to donate RUMlog via Paypal, you can do this here:
https://www.paypal.com/cgi-bin/webscr?c ... id=5908197
To see reviews on eHam.net or to write your own review visit: http://www.eham.net/reviews/detail/7821
4.0.1 - DX-Cluster font selection works again
Posted: Sat 8. Aug 2009, 08:31
The font size selection in the dx cluster windows is working again, this was broken in 4.0
Tnx to Leo, DK5PR for the hint.
http://dl2rum.de/rumsoft/rumlognews.html
RUMlog Version 4.0.3
Posted: Tue 18. Aug 2009, 15:09
Google Maps is working again.
When you see this:
GM-Error.tiff
GM-Error.tiff (25.62 KiB) Viewed 9247 times
GM-Error.tiff
You have to update to 4.0.3. Only RUMlog.app was changed.
Re: RUMlog Version 4.0.3
Posted: Fri 21. Aug 2009, 05:21
by KL7MJ
Tom -
This version looks great! One little bug that I have found is that it does not like 80m. It records "??" for the band, as well as exports it as "??". I haven't tried all of the bands yet, nor tried logging satellites - yet, but this version looks like a huge update!
Mike, KL7MJ
Re:Band shows ??
Posted: Fri 21. Aug 2009, 13:38
Tnx Mike,
make sure your settings under the QRG/mode tab are correct and correspond with your band plan. As default, the European band plan is used. Only frequencies between 3500 and 3800 will be recognized for 80m.
RUMlog Version 4.0.4 - Locator lookup works again
Posted: Mon 24. Aug 2009, 15:48
The internet based station's locator search is working again. This was broken due to changes on server's side.
Re: RUMlog Version 4.0.4
Posted: Wed 23. Sep 2009, 04:38
by KL7MJ
Tom -
I corrected the bandplan, and now it works perfectly! Thank you.
Mike, KL7MJ
