Yaesu FT-991a CAT settings for Rumlogng?
Posted: Sat 9. Jan 2021, 18:08
I have a Yaesu FT-991a and I'm able to connect it to WSJT-X no problem whatsoever.
My Settings for WSJT-X are as follows
Baud: 38400
Data Bits: 8
Stop Bits: 1
Handshake: Default
Force Control Lines: nothing
PTT: Method CAT
Mode: Data/Pkt
Split Op: Rig
When setting up in RumlogNG I have
Interface: Serial
For PTT Use: TRX CAT?
Baud Rate: 38400
Stop Bits: 1
Parity: Even?
Flow Control: ?
Power Up Lines:?
I cannot for the life of me get Rumlog to communicate with the radio properly, WSJT-X is NOT running.
Anyone have settings for use with the Yaesu FT-991 or FT-991a?
73s
K7DZE
Baud: 38400
Data Bits: 8
Stop Bits: 1
Handshake: Default
PTT: Method CAT
Mode: Data/Pkt
Split Op: Rig
Interface: Serial
Baud Rate: 38400
Stop Bits: 1
Parity: Even?
Flow Control: ?
Power Up Lines:?
73s
K7DZE
