Import ADIF/ADX QSL Handling when no info is found
Posted: Mon 14. Dec 2020, 14:42
by SV1QFV
It may sounds funny but i am confused about the different options...(Version 5.1.1 (455))
When using: Slot not paper cfd what is the expected behaviour during import ? (i am importing from WSJT-X)
QSL/W - LoW/W - eQ/W ?
There are cases that QSL is being inserted with W, other cases are not. Based on what information on the adif is populating the QSL column ?
I am missing something here
Thank in advance,
SV1QFV
Re: Import ADIF/ADX QSL Handling when no info is found
Posted: Mon 14. Dec 2020, 15:23
LoTW and eQSL will be set always to "W".
If you have the slot already confirmed with a paper card, QSL will be set to "-" otherwise to "W".
Posted: Mon 14. Dec 2020, 15:59
by SV1QFV
Thank you for the quick reply !!! I really appreciate it
