Mode Correction, MTORFEC --> AMTORFEC ?
Posted: Wed 2. Dec 2020, 02:42
by af8a
Hello Tom - I received a rejection from LOTW for uploading QSOs marked with mode MTORFEC in RUMLogNG. In checking the ADIF standard 3.1.1, I believe the designator should be AMTORFEC (a submode of TOR). Please review for a future update. Tnx es 73 de Gary, AF8A.
Re: Mode Correction, MTORFEC --> AMTORFEC ?
Posted: Wed 2. Dec 2020, 09:52
I will add an A. Tnx for the hint.
Until I'm going to buy an A, you can add it yourself: Edit carefully the file Modes&Submodes.txt
The file is located in your users directory: ~/Library/Containers/de.dl2rum.RUMlogNG/Data/Library/Application Support/de.dl2rum.RUMlogNG/
In Big Sur here: ~/Library/Containers/RUMlogNG/Data/Library/Application Support/de.dl2rum.RUMlogNG/
Posted: Wed 2. Dec 2020, 16:25
by af8a
Editing the txt file worked well. Those QSOs uploaded successfully to LoTW, and now I will continue entering my paper logs from the 1980's. Thank you.
