Log US County entries changing ("%2C" and "%20")
BMWrider
Unread post by BMWrider »
I'm running the latest version of RUMlogNG with the iCloud synced logbook on a MacBook Pro with macOS 10.15.7 (Catalina). I participated in the November SSB Sweepstakes and imported the QSOs from the contest log into my normal/primary log. I used QSO -> Add QSO Data -> use HamQTH.com to populate the empty fields. Afterward, the QSO US County entry changed un-commanded to replace commas with "%2C" and spaces with"%20". For example, "CA,SAN DIEGO" changed to "CA%2CSAN%20DIEGO". I corrected the entries, and after a few minutes many of the US County entries changed back to include the "%2C" and/or "%20". I tried an experiment where I used HamQTH.com for some log entries and QRZ.com for others. Regardless of data source, the US County entries reverted to include the "%20" and "%2C". Is this an anomaly with the iCloud synced logbook? It is related to the changing of LoTW status from "S" to "W" that I also experienced?
Bruce F | KF0ADW
Re: Log US County entries changing ("%2C" and "%20")
Bruce, pse check this version if it shows correct: https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip
BMWrider
Yes, that version of the app corrected the errors.
Bruce F | KF0ADW
BMWrider
I'm experiencing a similar issue as above with blanks and special characters getting "remapped" within the User_1 field. I use User_1 to document which antenna I'm using on each QSO. For example, one of the options (set up in a drop-down menu) is 71' EFW. That will become 71%27%20EFW at some point in the synchronization process. It seems to occur more often when I edit multiple records at once. Hopefully it's an easy fix, like the previous issue with Counties. I'm using the iCloud logbook on MacOS Big Sur (11.0.1).
Thanks for everything, RUMlogNG is AWESOME!
Cheers & 73,
Bruce F.
Yes, it seems to be the same problem. It will be fixed in the next update.
