For POTA, IOTA, etc only certain fields are required.
QSO Call Sign
Freq
Sent
Rcvd
QTH
Time Zulu
Date
Mode
MY PARK
P2P Only added as necessary per qso
Is there any to set up RUMlog so that only the fields I want to see on the logging page show up? Othewise.. instead of Tab.. it's Tab tab tab to get to the desired field then hit Add QSO
Not sure if this is clear.. but hope so.
POTA Question
Re: POTA Question
Would you be open to creating a contest module for POTA (Parks on the Air)? The previous posters field list looks good. The My Park field maps to the my_sig_info adif field and the P2P (park to park) field maps to sig_info.
Thank you for your consideration.
Re: POTA Question
I am following up to see if you have seen my previous question. Thank you.
Re: POTA Question
You can always use the General contest template. Enter the required data instead the control numbers. Export as ADIF and just exchange the ADIF tags <srx_string> and <stx_string> to whatever you need.
