DXLab Commander problem
Posted: Tue 7. Jul 2020, 12:38
I am using the DXLab commander feature in RumlogNG to retrieve information about the radio state for some other software I am integrating. I am using the command CmdGetFreq to retrieve the radio frequency. This works fine for the Kenwood 850 and the Elecraft K2. But when I switch to an Icom 756 non pro, the response is always .000 which according to the DxLab docs means the radio did not report its frequency. However the frequency is correct in Rumlog and it follows the radio, so Rumlog is communicating with the radio knows the frequency. The mode command CmdSendMode reports the correct mode and updates with the radio, so it appears to be something with the frequency.
Jeff
Jeff
