New LOTW record not working.
Posted: Mon 8. Jun 2020, 09:11
I changed callsigns (A45WG -> DU3TW), and so I got a new cert from the ARRL. After a couple of contests, I manually uploaded the ADIF using the ARRL software - all works. No issue with passwords, certs etc.
But when I try and do the same in RUMLogNG Specifically (QSL -> LOTW for new QSOs) - I get a DialogBox headed TSQLError with a Text field of "Command syntax error". This is a slight improvement on the previous error, which was Locale-unknown en_PH (The Mac had applied the regional settings on my behalf), I am forcing the Locale settings to be en_UK; And now we progress to the TSQLError.
If there any way I can debug/see what the error in the Upload to LOTW is ?? WireShark ???
The Menu entry QSL -> LOTW in, Does work; Annoyingly.
Regards
Tim
Regards
Tim
