tcp error 102 lotw
iz2eer
tcp error 102 lotw
Unread post by iz2eer »
good evening everyone
I use a version of rumlog 4.8.1 on osx 10.6.8
i am trying to connect to lotw (qslin) but i always get a tcp 102 error, both if i use the modem at home and if i use an iphone connection. Is it a site error or is there a compatibility problem with the old version of rumlog?
Thank you so much for your help
Re: tcp error 102 lotw
No problems here. You should consider the following:
  • The ARRL is currently working oil the LoTW system.
  • You MacOS may not support any longer the required security mechanisms.
iz2eer
ok many thanks
best 73 Dario iz2eer
