RUMlog 3.9 - With Gray Line Map
• Support for IC-7800 added
• Grayline map added
To open the grayline map window select Menu-->Window-->Grayline Map. The map window is free resizable. The width of the grayline can be set in the Preferences below the General tab. The red pin represents your location. When entering a call sign into the logging mask, the default dxcc location will be shown using a blue pin. The short path will be drawn with a red line. If the distance greater than 6000km, the long path will be drawn using a magenta line.
You can mouse click everywhere in the map. The grid square, the distance and the path will be shown. If you want see a path not from your home station, hold down the Command Key, while clicking on the new origin. Release the key and mouse click the second location.
My special thanks goes to the German Ham radio magazine "Funkamateur" http://www.funkamateur.de/, for providing this excellent map.
Read the attached What's new??? file (http://dl2rum.de/rumsoft/rumlognews.html) in the RUMlog folder for further information.
Grayline.tiff
Grayline.tiff (278.14 KiB) Viewed 6590 times
Grayline.tiff
K6LE
Re: RUMlog 3.9 - With Gray Line Map
Unread post by K6LE »
Map looks great!
Once again, Thanks,
Rick
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
leo_dk5pr
Unread post by leo_dk5pr »
Great job, fine business Tom!
Tks es 73, Leo
DK5PR
DG5MMQ
Unread post by DG5MMQ »
Top!
Danke
