Window positions in Catalina
g0vgs
Unread post by g0vgs »
Hi Tom et all,
Is anyone else having an issue in Catalina of RUMLgNG not remembering its window positions at startup?
Running the latest version of RUMLogNG
73 Ian
Ian J Maude | G0VGS
K3s #10268
K3DCW
Re: Window positions in Catalina
Unread post by K3DCW »
g0vgs wrote: ↑Fri 25. Oct 2019, 08:05 Hi Tom et all,
Ian,
Works as expected here. Are you running multiple monitors? If so, there's a setting that causes applications to default to the main screen rather than the secondary, although I don't know if this is your situation. I'm not in front of my Mac right now, but I believe it is labeled something like "use separate spaces for each desktop" or something like that.
Dave
K3DCW
"Hamming it up on macOS"
g0vgs
Thanks for the reply. I am running 2 monitors and RumLogNG starts quite happily on the second screen but only occasionally remembers the window positions. Most of the time, it simply all stacks on top of itself.
73 Ian
Ian J Maude | G0VGS
K3s #10268
