lotw setting
lu6oa
lotw setting
Unread post by lu6oa »
I need help configuring lotw setting in window (Select patch tqsl Folder), I go to the folder "Aplication" Tqsl is shaded and cannot be opened.
Please I need help. the database was deleted and I can't enter data in the program, I send a photo of the main screen and the error when I try to enter a callsign.
tks. LU6OA (oscar)
Re: lotw setting
Your .tqsl folder is located in your users home directory. Note the leading period in .tqsl!
lu6oa
Re: lotw setting
mpossible to configure lotw, I don't understand why my TQSL folder, when I try in the window "selections path to the Tqsl folder"
I go to the tqsl folder is disabled, please can you send me the routine according to my Finder.
thank you.-
tks. LU6OA (oscar)
Re: lotw setting
See the attached screen shot.
My computer is named MBP2019
My drive is named Macintosh HD
My user (German word is Benutzer) is named dl2rum
lu6oa
Re: lotw setting
Hello friend, I'm sorry, I can't configure, graphic sending, the TQSL folder is not available, I can't click on the File.-
tks. LU6OA (oscar)
Re: lotw setting
tqsl.app is not the .tqsl folder! The .tqsl folder will be created by the tqsl application automatically. Do you have got tqsl configured and running?
You can't see this folder in the Finder, it's hidden! But you should find it using the provided button Path to .tqsl folder
lu6oa
Re: lotw setting
Hi ..! I have running TQSL outside the Rumlog , I have no problems to execute it, but in the Finder it is hidden with shadow, load again the Trusted QSL program and run it without problems outside the Rumlog program, but in Preference, Rumlog does not find the Tqsl route.
Thank you very much for the assistance and patience.
Sorry, my English is not very good
LU6OA, Oscar
tks. LU6OA (oscar)
Re: lotw setting
I'm sure it is there! You should find out how to view hidden files on your system. On a German system I have to press Shift & Command & Period in a Finder window.
lu6oa
Re: lotw setting
Hi Tom, impossible, I can not configure loTw in RumLog, if you have any other solution for me let me know. Thank you.-
LU6OA, Oscar
tks. LU6OA (oscar)
Re: lotw setting
You could allow me to remote control your computer via iMessage.
