Steppir controller
NN7M
Steppir controller
Unread post by NN7M »
I’ll be adding a steppir controller to my system in a month or so. I would like it to get frequency info from the Mac to tune the antenna. Is there a way to do this with RunlogNG?
Re: Steppir controller
You have multiple options:
  • Read frequency via AppleScript
  • Use a DX-Lab-Suite Commander Client
  • Listen to the N1MM compatible UDP broadcasts
NN7M
Is there a piece of Mac software that will listen to the N1MM compatible UDP broadcasts? This seems like the most straightforward solution.
