1 does not work in contest window
hanz
Unread post by hanz »
OM's
When i press a one(1) in the callsign textfield in the contest window(HF europe right now) it is not accepted, when a paste a one it is accepted.
I checkeds keyboard shorts cuts but can't find anything.
Any idea?
thanks hanz
Re: 1 does not work in contest window
Check your contest CW and RTTY preferences if you have assigned the 1 key to start the exchange.
hanz
DL2RUM wrote: Sat 3. Aug 2019, 13:06 Check your contest CW and RTTY preferences if you have assigned the 1 key to start the exchange.
Many Thanks Tom,
That cured it thanks thanks.
hanz
