DX spotting
Posted: Tue 30. Oct 2018, 15:34
Used RUMlogNG for the first time in CQWW this past weekend. Thanks so much for all the work associated with creating this great software.
I had one question.. when in contest mode and I want to spot either the station I have entered in the callsign field or the Q already logged (most recently logged), how do I do that?? The macros in the terminal window don’t seem to pick up the contest log current or previous callsign (and associated freq). I resorted to manually typing in the cluster terminal window. I was wondering if there was a way or setting to get the terminal macros to pick up the call and freq info from the contest log? Or maybe there is a shortcut key sequence that would allow you to spot the call in the callsign field or the most recently logged call?
Thanks much
Scott, N3RA
Thanks much
Scott, N3RA
