Two monitors
F5HFZ
Two monitors
Unread post by F5HFZ »
Hi
Using a laptop (MBP) with an external monitor I wonder it's possible to memorize the positions of the different windows on the two screens ?
On the other hand I don't quiet understand in the "Window" menu the items "Show next tab", "Merge all windows" ...etc which remain grey all the time. It's maybe the solution ?
Any help will appreciated
Best 73
Nicolas, F5HFZ
Re: Two monitors
macOS may be a bit tricky to find the correct settings to fix the windows on multiple monitors. External tools are available for more comfort. I use an iMac 5k with a second monitor without problems and without a third party software.
Some menu items will be added by macOS, they are useless for RUMlog.
F5HFZ
Re: Two monitors
Thanks Tom, I will try to find a third party software to fix the problem.
Do you have a name for a good one ?
Best 73
BTW the 7610 CTL with the spectrum is awesome.
Nicolas F5HFZ
