help with LoTW
Posted: Thu 25. Oct 2018, 13:56
by wx5atx
ok I was able to find the path to the .tqsl folder. now it says "sandbox error" "start tqsl manually first and reset path settings in preferences" im not sure what im doing wrong and what else I need to do?
Re: help with LoTW
Posted: Thu 25. Oct 2018, 14:12
It seems you made nothing wrong until now.
Make sure TQSL is located in your Application folder and start it manually. When it works and all settings are made quit it. Go to the RUMlog Preferences under the LoTW tab and select again the path to the TQSL application. Try again to upload.
