Bug report: Import/export QSO times
Posted: Wed 15. Aug 2018, 09:56
by M0NZO
Hi Tom
Just a quick bug report. I hope this is the right place.
RUMlogNG Version 3.12.2 (252)
I am importing an ADIF into RUMlog, which contains the following fields:
<TIME_ON:6>093000
<TIME_OFF:6>100000
As RUMlog only has one time field by default, the value from the TIME_OFF field is used.
However, when I export the QSO from RUMlog to ADIF again, the time now appears in the TIME_ON field:
This means that all of the times for imported QSOs have been transposed, so they start at the time they actually finished. As a result, the QSOs don't match when uploaded to LoTW or eQSL.
Please let me know if you need any further information.
Re: Bug report: Import/export QSO times
Posted: Wed 15. Aug 2018, 10:16
You are right, this is the way it works.
I'm in a conflict. As default RUMlog saves the time when you press the Save QSO button. This is normally the QSO off time. The ADIF specification recommends to use the <TIME_ON> tag as minimum in a data record. There are services out there, accepting the <TIME_ON> only, not the <TIME_OFF> tag. That's why RUMlog exports <TIME_ON> tag.
You can go to Preferences-->General and define a user field as <TIME_ON> field. Then RUMlog will save, import and export both times.
Posted: Wed 15. Aug 2018, 10:36
by M0NZO
Hi Tom
Thanks for your reply.
DL2RUM wrote:I'm in a conflict. As default RUMlog saves the time when you press the Save QSO button. This is normally the QSO off time. The ADIF specification recommends to use the <TIME_ON> tag as minimum in a data record. There are services out there, accepting the <TIME_ON> only, not the <TIME_OFF> tag. That's why RUMlog exports <TIME_ON> tag.
I understand, but as a result, incorrect times are being exported.
The way other loggers that I have used work around this problem is to populate the TIME_ON field when the callsign is entered (or looked up) and the TIME_OFF field when the QSO is saved. Would it be possible to do something like this?
I did try doing that, but found that I would have to type the TIME_ON for each QSO. Also, I am currently using the 4 user fields for other things.
Posted: Wed 15. Aug 2018, 11:53
No! Just enter the callsign and press the Tab key to set the QSO start time.
Furthermore you can edit the ADIF file to match your needs.
Posted: Wed 15. Aug 2018, 16:40
by M0NZO
DL2RUM wrote:No! Just enter the callsign and press the Tab key to set the QSO start time.
Thanks Tom, that's good to know. Now I just need to decide which of the other user fields to lose. If only there were 5 or 6 custom fields
