RUMlog FAQ
Re: Import Error messages?
n2fq wrote:Hello.
Where does Rumlog put these error messages?
They scroll up to fast to read and there is no scrollbar
in the window to scroll to the beginning.
tnx. 73 Fernando N2FQ
There should be a scrollbar. The errors are not saved, or otherwise accessible except in this window.
A very common failure is a not correct set frequency table in the Preferences under the QRG/Mode tab. Make sure, these settings agree with the band plan in your region.
If you have further trouble, I could try it for you. Please e-mail me your ADIF file.
n2fq
Re: RUMlog FAQ
Unread post by n2fq »
Thank you Tom for the response.
The scrollbar doesn't appear until I click the cursor on the right side of the window.
That's minor and now I do see it.
You are correct about the freq.
My adif has the freq in MHZ and I suppose RUMlog is looking
for it in Khz. I'll edit it them and try again.
take care and tnx agn. 73 N2FQ
Re: RUMlog FAQ
In accordance with the ADIF specs, frequencies are always given in MHz! There must be another problem.
What is the error message?
n2fq
Re: RUMlog FAQ
All fixed now. I had a run of entries with freq of 7.45 where it
should have been 7.045. Inspecting the import error msgs more closely
revealed it.
tnx agn for you prompt reply.
73 Fernando N2FQ
PA9CW
4 meter
Unread post by PA9CW »
I entered a 4 meter QSO in Rumlog ( version 5.13 ). But in the DXCC list, I do not see 4 meter.
Is there a solution to get 4 meter QSO's in the DXCC list ?
rumlog.tiff
rumlog.tiff (39.28 KiB) Viewed 10001 times
rumlog.tiff
Re: RUMlog FAQ
No, there is no support for that.
