DL2RUM wrote:I've just tested the TS-570D setup. All works as expected. I'm sure, you have a failure in your setup. I pointed out already to two errors in your settings.
I don't doubt that you have a fully working set up... me though, I am very much a learner. However, when I change the PTT from RTS to CAT in WSJT-X preferences, the configuration fails the '
Test CAT' test and returns a RED failure warning.
I am at a loss as to what to do.
I wonder if you would be kind enough to screenshot your settings for me please, and also describe the cable set-up you have from the Mac to the rig. This would allow me to triple check things. I use two cables (as indicated in PDF in the new thread I posted) on my TS570D; one is the FTDI CAT Control cable from the RS232 port to a free USB port, the other is a data mode cable which converts the audio and mic in/out to 3.5mm connections, plus acts as a PTT function when the rig is in TX mode (if I didn't use that the rig takes its audio input from the hand held microphone via VOX instead).
I really do appreciate your help here, many thanks.
