Saving qso though WS-JTX
Posted: Sun 4. Feb 2018, 21:30
by IV3TMM
Hello, i'm using WS-JTX linked with RumLogNG and everything is running OK.
When i want to do a qso with JT i double click over the call in the JTX window RX.
So, the input qso window in RumLogNG populate his fields correctly with also the user defined field 2 and 3 where i have automatically inserted my Callsign as Operator and my WWLocator.
At the end of the qso RRR a new desktop window is opened by JTX and when i confirm to save qso, RumLogNG insert the new qso in his database BUT WITHOUT THE FIELD 2 AND 3 that is inserted empty.
Please could you check the bug ?
TY and ciao.
Re: Saving qso though WS-JTX
Posted: Mon 5. Feb 2018, 05:24
This isn't really a bug. This function is just not included. It logs only QSO data provided by WSJT-X. I have to consider to add it.
Posted: Mon 5. Feb 2018, 18:26
by IV3TMM
Rgr that and ty for update.
If i remember correct with the version 3.9 it runs. Don' t sure at 100%.
But probably because i used JT-Bridge before to save qso on RumLogNG ? and not now with 3.10 version ? Is possible that ?
But i think so.
Ciao.
Posted: Mon 5. Feb 2018, 18:30
No changes so far. You can disable the automatic logging feature. Save the QSO manually.
Posted: Sat 3. Mar 2018, 19:10
by themusicman
... if you do this, does it still mark the contact as worked and the DX country also as worked?
