CAT CONTROL FT-450D doesn't work
va2cz
Unread post by va2cz »
Hi everyone,
A friend of mine, Jean-François VE2JFM, try since several days to configure is RumLogNG with his Yaesu FT-450D without success.
Now, he need your help.
Here is the setting... He sees the USB port in the preference, Baud rate : 4800 , Stop Bits 1, Flow Control RTS/CTS Checked.
Thank you in advance
73, Pierre, VA2CZ
Re: CAT CONTROL FT-450D doesn't work
Make sure all mentioned settings match settings in the trx menu. All can be changed. In which colours are the labels Mode and kHz next toi the logging fields written?
