Editing Cabriilo templates (issue with ARRL Sweepstakes)
Posted: Mon 20. Nov 2017, 17:44
by w6ipa
Is there a way to edit the template used to generate the cabrillo files for a context ?
I don't know if i did something wrong (it was my first contest) but the cabrillo file generated for the November ARRL sweepstake contest
Was missing a space between the send section and and the received call sign.
JC
Re: Editing Cabriilo templates (issue with ARRL Sweepstakes)
Posted: Mon 20. Nov 2017, 18:30
No.
Can you post few lines of the Cabrillo log please?
Posted: Mon 20. Nov 2017, 19:37
by w6ipa
Here is what is generated:
QSO: 7267 PH 2017-11-20 0121 W6IPA 013 B W6IPA 07 SCVW6DR 779 M W6DR 80 SCV
Here is the correct one:
QSO: 7267 PH 2017-11-20 0121 W6IPA 013 B 07 SCV W6DR 779 M 80 SCV
I messed up by actually putting the call sign in log, but it would be useful to have better visibility into the fields that are expected on a per contest basis (from the RumlogNG point of view) and compare to the contest rules.
JC
Posted: Mon 20. Nov 2017, 19:48
You put your call and the dx call into the control number. This is not required and not part of the Cabrillo log.
But I know, you have to send it.
Posted: Mon 20. Nov 2017, 20:49
by w6ipa
Yes, that part I didn't do correctly, but there is missing space between the section (SCV) and the other call sign.
Also, one thing i did not find is how to modify my side after the contest has started, I cannot edit the setting.
JC
